Bravo III Propellers
Freeloader
22 Mar 2007
Home: Rutland, Boat: Poole.
Earlier this summer I purchased a Regal 2250 Cuddy that is fitted with a Mercruiser 5.7L 350MAG 300hp motor and Bravo III twin-prop sterndrive unit (the highest spec motor and drive combination available for this model).
The boat is 22' long, with a beam of 8'-6" and weighs 4,400lbs (actual weight on a weighbridge). The performance with the standard 26" Mercury 3x3 Bravo III propellers is pretty good all round, with a 0-30mph time of around 7 seconds and a top speed of around 53mph (GPS) at 5,100rpm WOT (WOT range 4,800-5,200rpm).
I started looking around for a spare propeller set simply to keep on board in case of emergency. From my test results, I took it that the current 26" pitch is about right for my boat and thought that I would therefore get a similar 26” 3x3 set. However, I have found that Mercury now do a 4x3 Bravo III propeller set (in matte or high-gloss) and a 4x3 Bravo III XR – i.e. a 4-blade front propeller and a 3-blade rear. I use my boat primarily for water sports and so the 4x3 setup may be beneficial, although I wouldn’t want to take too much out of the top end.
It appears that the XR may be designed more for bigger boats with big-block V8’s, so I take it that the standard Mercury Bravo III 4x3 propeller would be the most suitable for my boat. Does anyone have any experience with going from a 3x3 to a 4x3 prop and have any information on the relative performance differences between the two?
I have also found an independent propeller supplier, Hill Marine, who manufacture Signature 4x4 propellers for the Bravo III drive – i.e. a 4-blade propeller front and rear. Again, I would be interested to hear from anyone who has experience of these propellers. Additionally, I would be interested to know whether they are as robust as the Mercury items? My 3x3 Mercury propellers are constructed of a fairly thick stainless steel and seem to withstand occasionally churning up sediment in shallow water. Some propellers I have owned in the past were made of far thinner stainless and would not take that kind of abuse – how do the Hill Marine propellers compare?
Thank you in advance!
Sorry, I can't help you with the specific comparisons you're looking for.
But when looking for alternative props, the key factor is always understanding how the existing setup performs, before thinking of anything else.
And to evaluate that, you should add to the numbers you already posted also the outdrive ratio.
By heart, I would have said it's 1:1.85, in which case your slip would be way too high. But maybe the ratio is higher, like 1:2, dunno...?
Hi Mapism,
Yes, the drive ratio is a lot higher at 2.2:1 and so the prop slip is actually very good at only around 8%.
I have no concerns about my current setup as it seems to be performing fine and is absolutely spot on to Regal's published criteria for top speed (53mph) and cruising speed / revs / fuel burn (33mph / 3,500rpm / 38 litres per hour).
Perhaps I wasn't very clear in my original post but I'm not actually trying to tackle any particular performance issue, just looking to get a spare prop and ancillary nuts/bolts to keep on board. I was, therefore, simply going to look for an identical prop set to the one I have but came across the 4x3 props and wondered whether this might be an interesting alternative.
Thanks for the input though!
Well, a 2.2 ratio drive with a 26" prop and 53mph at 5100rpm actually means just 7.1% slip, which is indeed an excellent result.
Btw, I wasn't even aware that the B3 is available with such ratio.
As they say, if it ain't broke... I'd stick to the very same props also as spares.
It's very unlikely that 4 blades props will bring you any benefit, because you already have plenty of acceleration for water sports, and I'd rather expect them to reduce your WOT speed.
Good luck, whatever will be your final choice! :)
Mapism - Yes, perhaps you are right. If the newer 4x3 props could match the top end of my current 3x3 props, whilst also getting more acceleration, then I would definitely be interested. However, I suspect not...
Markdj - Thank you for the offer - PM sent!
