Brass Self Tapping Screws
colhel
9 Jan 2011
Gillingham(Dorset) Boat Weymuff
Anyone know of a source to buy about 100 brass self tappers, about 15mm long, I want to re-knew the ones in the cabin. I've seen them at Piplers I think, but only in small qty bags IIRC which could work out a bit pricey. Also brass "cup" washers to suit.
Thank You
Billjratt
9 Sep 2004
Firth of Clyde
OP mentions cup-washers, so is it possible we are talking ordinary countersunk woodscrews here?
Agree the torsion on a brass self-tapper-shaped screw would probably wreck it going in - or if not, it would never come out again in one piece- but I've never seen any.
Internal cabin-work should be OK for brass - or seems to be on my 1978 boat. I always grease them before inserting.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Will stainless steel ones from Toolstation do? £3.65 for 200 in the size you want, here. They don't seem to do screw cups but Screwfix do, here. £2.68 for 100. Unfortunately I can't find nickel plated brass, which would match the stainless screws, but those linked are brass.
colhel
9 Jan 2011
I think we are yes :eek: . Thanks for correcting me. Do you know where I can get some?
andygc
7 Jan 2007
Devon
I would'nt touch brass in a marine environment even if there is such a thing as a brass self tapper.Probably only last about seven years at best before breaking down.
It depends on the quality of the brass, where they are and what they are used for. In the last few years I've removed quite a few brass screws from my boat whilst working on it. On deck they tend to break down, but in the cabin I've had very few problems. The majority of the screws I've removed were first fitted between 1971 and 1974 - a tad longer than 7 years. If all they are doing is holding interior trim then brass should be OK, but if the originals are brass then they'll be woodscrews, not self-tappers.
I've just replaced two brass wear strips on my coaming - removed to make a better job of the stripping and refinishing. They clearly haven't been removed since the 1970s and one quarter of the screws were waisted and sheared. The rest came out fine. I reckon the replacements should be good for another 30-40 years, but the coaming probably won't, so why buy bronze?
andygc
7 Jan 2007
Devon
Screwfix sell brass screws which will match their screw cups, but unfortunately the quality is poor.
22 Apr 2009
Just driftin
Brass age hardens quite apart from anything else & was originally designed for ornaments so unless your boat builder was particularly crumby I suspect your deck fittings were bronze.
The recent scandal about brass through hull fittings should be enough to put anyone off & I don't think I would trust any boat builder nowadays who uses brass when stainless steel is available.(other opinions are available).
andygc
7 Jan 2007
Devon
I do know the difference. There's also very few places for stainless steel fastenings in a 65 year old boat that's built of oak.
