Brass or bronze?
Sitka 291i is a sealant and adhesive which will work fine but is more difficult to remove the fitting next time so better to use non adhesive sealant perhaps butyl tape.
I thought I would add that as I commented earlier , I fitted a Marelon seacock to my heads outlet.
However , I used a new DZR hull fitting and a DZR elbow either side of it and used Sika 291i to seal and adhese it all together.
As far as I can tell this works fine.
One issue I noted was that getting the retataining nut tight on the tail piece was very difficult in the tiny spaces you have to work in on boats.
I made a note to try and give it a final go at getting it tight enough the following day (it was not not loose it's just that you want to be sure) , however the 291i had cured and the whole assembly was absolutely secure.
Can't think as I write if 291i is a sealant or a sealant AND adhesive but it is reccomended for the job , as well as others of course.
