Brass hinges
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
Looking for some solid brass flush hinges 51mm x 19mm to replace some rusy horribel brass plated ones.
Only place I can find any is Force 4 at £8.95 a pair, which seems excessive. Anyone got any other sources?
- W
I've had some in the past which were brass with stainless hinge pins but more recent ones were solid brass with brass pins. Lots around which were brass with mild steel pins which of course RUST!! Sorry cant remember where I got them from.
A few years back I bought some off ebay. They were solid brass, including the pins, and cost me lots less. They were from a seller in the UK.
It would also be helpful if there was more standardisation. It's annoying when you buy the right sized hinges but the holes don't line up with the holes in the timber, which then have to be plugged and re-drilled.
I do that, not worth buying stuff to last for what I want so I buy cheap and chuck it away, if I need the same tool again I'll buy another new one and still be quids in.
I used to know a car-restorer who bought £15 angle-grinders in batches and treated them as consumables :)
