BartW
Have been doing some refurbish work on one old toilet flushing pump
and replaced a 1,5" one way valve.
I bought this Check valve and a few extra fittings from a Belgium "water systems parts shop" nothing todo with marine, nor seawater,
I didn't give this attention when I bought them, but realise that these parts material is "messing"
the Original fittings on our Canados might be bronze ? or "Corrosion Resistant Brass " (?)
the Original fittings and the pump have been filled with seawater the past 25 years, I guess they have been cleaned before my time, (+7y ago) but the fittings and the pumps are in amazingly good condition.
how can one see the difference between messing, brass or bronze ?
is messing good enough for seawater ?
a few years ago I have replaced my airco primary cirquit seawater pump with a stainless steel model (purchased from a local pump shop in France, not for marine)
so how about stainless steel for sea water.
I'm not sure if or when the seacocks on our boat have been replaced,
afaik they have'nt the last 9 years.
Is it ok to check them during liftout; slightly grind them and sheck if the bronze (?) is still glossy ( inside aswell as outside) and no trace of corrosion,
Or should they be replaced preventive anyway ?
