C08
I have fitted a bow thruster and I am wondering about the charging system options and drawbacks.
The thruster will operate from a dedicated starter battery in the bows. The charging will need to come from the battery compartment area where I have banks of 2 & 3 110AH leisure batteries. I do not fancy fitting heavy duty cables back to the rear of the boat, about 12Mx2 cables on the grounds of cost and the heavy cable routing. I plan to have a twin core charging wire (2.5mm/29A) with an inline 20A fuse and an isolating plug at the battery compartment end. Under way the charging isolator plug will hang over the thruster joystick so the thruster will only normally operate from the starter battery. In the event that the plug is left in the in line fuse fuse should blow and protect the charger wiring.
Battery charging when I am off the boat is wind genny and 2x80w solar panels so the starter battery should always be pretty well fully charged and ready to go. Is there any flaw in what I plan to do or anything better. The thruster battery is over specced for the smallish thruster and being only 1 foot away should not have much voltage drop in the well sized cables.
