petem
Afternoon cabin? Sounds v posh
Afternoon cabin? Sounds v posh.
Do you mean voltage, rather than current? Check the connections in the 12v heavy duty box in the aft cabin wardrobe, sounds like a poor connection somewhere. In particular, it's worth checking that you're not getting a voltage drop over the isolator switch mounted in the very bottom of the box. And if you're getting a voltage drop at the bowthruster motor, check the other side of the solenoid in case it's that.
Yes voltage. I will see if I can make sense of this. Is the solenoid by the thruster?
Also when it packed up I think it overheated. Thruster box smelt warm. Not sure if that leaves a route to consider?
