Bow thruster sparking & carbon dust
trialframe
4 Nov 2003
Weymouth UK
On our Nordhavn 43 we have 12v Side Power bow and stern thrusters which are both working well. When checking the bow thruster compartment recently there was a thick layer of carbon dust on everything. Previously (for 5 years) it has been very clean in there. On observation of the motor running there is a lot of sparking at the brushes & fine carbon dust can be seen in the air.
The stern thruster motor gives almost no sparking or dust.
I checked the voltage under load and it is 11.6v which is well within spec.
I removed the motor and cleaned the armature with fine aluminium oxide paper. I also cleaned between the segments and checked that they are undercut - yes they are. I replaced the brushes with a new genuine set.
Unfortunately after all this there is no improvement.
Any ideas??
Was the com worn or have grooves , it sounds like it needs taking to a motor rewind firm and they will rebuild the com and bed in the brushes , then you can forget it .
Have you checked the battery connections / wiring connections to this bow motor .Even though the V appear ok a weak current might help spark that would otherwise not happen like @ the stern motor .
The motor is right next to the bow battery which is a 210 ah lifeline agm. I have checked the connections which appear to be good.
Maybe I need to source a clamp on meter to measure the current which should be in the order of 700 amps.
I have my Sidepower in with a very good (so it appears so far!) company at the moment. I can let you know how it goes. Osmotech use them for all of their electric motor work and rewinds, which is a good testimonial - and its a lot cheaper than going via the middle man.
Thanks Solent Sailor - it would be good to know for the future.
There has been a happy ending to my problem.
I took the motor to a small business called Borg EMR near Ferndown. Nick Borg stripped my motor, replaced the bearings (one was shot) and skimmed the commutator etc. Result - it's back to normal at a very reasonable cost & all done within one day.
