bonny
I'm thinking of fitting a bow thruster to my Beneteau Oceanis 393 but I suspect there are a few problems. I would be interested to know if anyone has one fitted, what make & model is fitted, performance etc.
Unlike most boats, the 393 has a walk through forward cabin to a forwards head. The problem is that the floor goes right forward, so no bunk to hide thruster in.
The only place I can see possible is behind the loo, under the forward holding tank. This does have the advantage that it's quite far forward so should give plenty of turning force, but unfortunately the draught this far forward is quite shallow. I've been told that a side-power 40 will fit but this seems a bit underpowered for a 12m (40ft) boat. Obviously I would like to fit a 60Kg model but I'm not sure if one will fit.
Other info:- I've had the boat for 5 years, which has a 3 blade volvo folding prop. Forward braking force is non-existant and she has tons of propwalk to port astern. I'm well used to handling her - even in tight quarters but a thruster - even an underpowered one will make things easier.
Any help or experience would be most appreciated.
