Avocet
Avocet's engine was burning oil last season. I finally got round to measuring-up my piston and cylinder this evening. I'm still somewhat puzzled as to what the problem might be though.
Nominal bore size is 82mm.
I measured it in about a dozen places and the highest measurement I got was 82.09, the lowest was 82.03. Average 82.056mm. I have two workshop manuals. One says the bore should be 82.0 +.01, -0. The other says Max. bore wear 0.15mm. I'm not sure I believe the first manual. I've a feeling those are manufacturing tolerances on a new cylinder rather than permitted wear? I think 0.15mm sounds much more believable for wear?
Anyway, if that second figure is correct, the bore is fine for wear.
I also measured up the piston and was a bit surprised to find it was slightly oval. The nominal diameter from the workshop manual is 81.97mm. I measured an average of 81.85mm across the gudgeon pin and 81.59 along it. Is that normal?
Lastly, I stuck the piston rings down the bores in various places and measured the gaps between the ends. The manual talks about 0.3 - 0.5mm for a new build, with a maximum permissible gap of 2.0mm. The top and middle rings showed gaps of about 0.7mm, but the oil scraper ring had a gap of 1.75mm.
I'd be grateful for any thoughts anyone might have!
(It's a BMW D12, by the way).
