Unfortunately, I can't wrap all around as the mainsail foot is held inside a slot along the top of the boom...
Although that was 14 years ago so it would be a fair bit more now,On the scale of boaty expenditure £472 for a new boom sounds fair value
I understand that, but if you read my post:Unfortunately, I can't wrap all around as the mainsail foot is held inside a slot along the top of the boom...
Oops... apologies for not reading properly! Sounds like a good plan.I understand that, but if you read my post:
Quote "If you use the same technique, then when the epoxy glass has cured, refit the SS kicking strap fitting, using it as a template to cut the keyhole slot , and carefully open up the slot for the mainsail bolt rope, assuming the main uses a bolt rope. I'd use monel pop rivets to fit the plate." End Quote.
You can easily cut a slot for the main sail bolt rope, you could use a dremmel, or a hacksaw blade, and fair it off with a file and/or sandpaper.
The reason I think an epoxy glass repair would work are as follows:
If you use a SS plate, it will be difficult to bend to shape, it'll need to be at least 2mm thick to be an effective repair, and you'll need to electrically isolate the SS from the aluminium.
If you weld an aluminium plate on top, you'll need to careful that you don't introduce weak points at the welds, the boom will be a tailored alloy for spar making, some on the forum will probably know what it's likely to be, it may even be heat treated, or may also mechanically worked for additional strength. The weld will introduce an undefined alloy at a high load point on the boom. You'll also have to paint or anodise the repair to protect the new aluminium plate, and then there's the issue of getting the boom to the welder or the welder to the boom.
An epoxy glass repair can be done on the boat on a fine day, and if done carefully, will be at least as strong as the alternatives. Think about flying in a modern aluminium, epoxy carbon fibre, commercial jet aircraft.
Yes, you can. The sail will probably set just fine loose footed. I've converted two boat from attached foot to loose foot. I like it better.Unfortunately, I can't wrap all around as the mainsail foot is held inside a slot along the top of the boom...
I think that's what finished off my boom!Yes, you can. The sail will probably set just fine loose footed. I've converted two boat from attached foot to loose foot. I like it better.
Hi,
my Twister 28's 50yr old aluminium boom has an area where a previous fitting has been removed leaving about 5 ugly holes all in close proximity. View attachment 82706
It's clearly a weak spot as well as an eyesore... What should I do?
Thanks!
Crisp
