captaina
I own a 46ft sloop, on our way to the Med.
I've suddenly decided to care about boom brakes to prevent or slow a gybe.
Who can advise on which is better...the Walder Boom Brake or the Wichard Gyb'Easy Boom Brake?
And...with either...surely neither stops the boom from going across, they both only stop it doing so undamped. So...in strong winds, wouldn't you also still need a preventer going from the end of the boom to the bow, then back again to a winch?
Someone has told me that both of the above can be a preventer if you use a clutch on each side, but I can't understand that...the thingy on the boom is explicitly designed to allow the boom to cross over slowly, so it is not secured like a normal preventer.
Advice appreciated!
Advice appreciated!
