Stemar
No problem. Next time I'm around Go Outdoors or similar, I'll pick up a carabiner and have a play.
Boom brake was fitted at the kicker. It wasn't 'on'. Lines were slack and not made off. Wind went from 5kts to 40kts around a headland. We healed over, I dumped the mainsheet and the friction in the boom brake, even though it wasn't supposed to be on, snapped a very substantial boom. We don't use one anymore!Was the brake attached at the kicker fitting or mainsheet fitting? What caused the damage? Dipped the boom end in the water? Or crash gybe?
We learn by our experiences, I’m sticking with a preventer then!Boom brake was fitted at the kicker. It wasn't 'on'. Lines were slack and not made off. Wind went from 5kts to 40kts around a headland. We healed over, I dumped the mainsheet and the friction in the boom brake, even though it wasn't supposed to be on, snapped a very substantial boom. We don't use one anymore!
Not possible to install a boom break to the end of our boom. We use twin preventers now and it works fine. No risk of boom damage.With the main sheet at the end of the boom and the brake in the middle your heading for disaster. Basic O level maths tells you the force of the couple acting on the point where the boom brake is fixed is huge.... and the boom is not designed to take such high side-on forces.
We saw 3 trans-Atlantic yachts come into A Coruna with in a couple of weeks with broken booms.
They're called boom brakes because they 'break' booms. They're for people that have everything they need, but want to spend more money.
I did see a much better idea on a big custom yacht in NL. It acted directly on the main sheet gathering it in and letting it out controlled by an clutch.... still it looked like a solution looking for a problem.
Jimmy Cornell probably didn't do O level mathsNot possible to install a boom break to the end of our boom. We use twin preventers now and it works fine. No risk of boom damage.
Jimmy Cornell swears by them. Fixed to the kicker location. Totally opposite of what you are saying, but I am with you. Not worth the trouble, cost or breakages when two lines work more safely?
Which book? Passion for the sea?Jimmy Cornell probably didn't do O level maths
In fact I'm pretty sure he was too busy avoiding bullets from the police... according to his amazing (highly recommended) book.
I can't remember. If not Passion.... maybe 200,000 miles.Which book? Passion for the sea?
A big Ben came and anchored next to us this morning in Cascais. Boom brake fixed to kicker location. Do you think I should tell him ?Not possible to install a boom break to the end of our boom. We use twin preventers now and it works fine. No risk of boom damage.
To be clear.... the boom brake needs to be fixed to the boom at the same point as the main sheet.... Otherwise you induce a bending couple in a direction the boom cross-section is not designed to take. Big Ben risks breaking his boom.A big Ben came and anchored next to us this morning in Cascais. Boom brake fixed to kicker location. Do you think I should tell him ?
That seems logical but it’s the first time I’ve seen that recommended. Most of the boom brake retailers seem to suggest attaching at the kicker point. Just schoolboy physics can see the massive load that will fall upon boom and gooseneck with a brake attached to the kicker attach point. I’m surprised not to have heard the gooseneck fittings have been broken in this manner.To be clear.... the boom brake needs to be fixed to the boom at the same point as the main sheet.... Otherwise you induce a bending couple in a direction the boom cross-section is not designed to take. Big Ben risks breaking his boom.
I don't understand that assertion. Surely when the boom brake is exerting its braking effect is when the boom is swinging freely and not influenced by the mainsheet?To be clear.... the boom brake needs to be fixed to the boom at the same point as the main sheet.... Otherwise you induce a bending couple in a direction the boom cross-section is not designed to take. Big Ben risks breaking his boom.
I think the discussion about fixing point is about the optimum position to minimise the lever effects on the boom. In a crash gybe the mainsheet is likely to be very loose as the boom swings overhead and therefore applying zero forceto the boom albeit momentarily.I don't understand that assertion. Surely when the boom brake is exerting its braking effect is when the boom is swinging freely and not influenced by the mainsheet?
Yes maybe that is what Brake designers intend, a substitute for sheeting the main through the gybe. Seen in that context a Brake is a lot of expense and additional rigging (trip ropes) for little gain.A boom brake might be a useful tool to execute a controlled gybe without sheeting in and out the main. That's maybe what the inventor/sellers intended. To prevent damage from an accidental gybe one might consider a preventer as a better solution... for all sorts of reasons. But if you where designing a device to mitigate the effects of an accidental gybe would some sort of shock absorber of decelerator be a much better idea?
Strikes me that any mainsheet configuration where the mainsheet is attached in front of or above the spray hood won‘t allow a brake to be fitted unless it is fitted at the kicker attachment fitting. And as discussed above it seems fitting a brake so close to the mast is asking for trouble. On my boat I can’t fit a brake at the mainsheet fitting as the lines would foul the windshield.how do boats with "german" type main sheet systems which are mounted on the coach roof and attached mid boom avoid the risk of the boom breaking in a situation such as described by @geem ?
Seems that they could / would exert similar forces to a boom brake unless the sheet was running freely, in which case the boom will presumably meet the shrouds and / or the sea in a bit of hurry which isn't ideal either.
