vas
good afternoon and a few more Q from me!
ripped all the bonding wires off MiToS (don't want to discuss their condition and securing...) and since I'm finishing cleaning the lazarette and e/r bilges I'm trying to figure out what bonding wires I should use.
I've done my studying (as always) and I'm slightly confused (again as always...)
now then, I'm going to bond all the metal underneath which is:
Z. engine (it's the longest from the anode at 4m routed)
A. stuffing box (? was bonded, do I need to though ?)
B. P bracket (1.5m to anode)
C. rudder (.5m to anode)
D. Anode (1kg thing on the transom)
NOTE:
All the above are times 2 as there's two engines to cater for
Note all skin fittings are GRP (Truedesign NZ) so no bonding on them and depth traducer is also plastic. No need to go through the wood == bronze fittings, as cold formed ply is quite stable and wont create any issues (IIRC BB also agrees on that)
Trim tabs do have 2 anodes each but are not bonded anywhere
Q1. Do I run one cable from each of the Z, A, B, C to the Anode, or do I daisy chain one from Z to A to B to C to D???
Q2. I guess it's good practice to join the two anodes together (they are half a metre apart)
Q3. What gauge wire do I use? From looking at the old ones and visually I'd say I'd be happy with AWG 5 or min 7 (in mm2 terms 16mm2 or least 10mm2 )
Q4. Type of wire to use:
option A. marine rated tined wire green colour (a hell of job trying to find it here!)
option B. pure solid copper wire (at least AWG5 in this case!) and yes it will be a bit tricky to route and i'll need to make sure I have springy loops to cater for vibrations and general movements.
what does the panel say?
cheers
V.
NOTE:
cheers
V.
