William_H
I would think that SS is much the same as aluminium to bond to. So yes no problem provided the surface is really clean and rough. Clean with acetone ensuring that each succesive wipe is with clean cloth and acetone. Aircraft Ali wing skins are often bond repaired with epoxy in a substrate.
Drilling holes in the SS where the fillet will cover will help a lot. What you could do is get kevlar strands to go from one side of ss through the hole and back through another hole facing both forward and aft. Like a lassoo through 2 holes with say 50mm of tag each side. It might be an idea if you do this to chamfer the holes edges so they can't cut the kevlar. If you can't get kevlar then glass strands will help. Use carbon fibre strands in the fillet for stiff strength.
Drilling SS is no problem witha bench drill press where a lot of pessure can be rought onto a slow turning bit. Make sure you get positive swathes of ss cut out. A larger drill bit is easy to sharpen provided you don't blunt it too much and carefully look at the cuttting angle to reproduce it. good luck olewill
