chriswesterman
Hi,
Details:
Engine Bukh DV20, manifold and Thermostat housing made of Cast Iron
The thread in the manifold which holds the Thermostat hosing bolt has stripped / enlarged and will not hold the bolt tight. The Bolt only has about 5mm of thread length into the manifold. The Original BUKH bolts are M6 70mm long ignoring the HEX bolt head
Now there is plenty of thread in the Manifold so I could get a longer bolt or I could helicoil the damaged thread.
Question:
Either way what material should either the bolt or helicoil be made out of ?
Regards
Chris
Details:
Question:
Regards
Chris
