boatone
A little while ago we had a thread discussing the whys and wherefores of what constituted use of a boat and whether a licence was needed.
An aquaintance of mine with connections has been kind enough to pursue the matter and has received the following statement which I believe comes from what is , in the vernacular, referred to as "a reliable source"
"This relates to the issue of defining 'use'. Basically, if you're on
your boat at all - making tea or sitting on it enjoying the view, you
need a licence. The only thing that you can currently be aboard for
without a licence is maintenance - and if there is any evidence of
occupation whilst undertaking maintanance or refit, that is regarded as
use. If our patrols catch people using a boat that is moored at the
bottom of a garden that isn't registered, they will be booked
unregistered. I believe this will change when the harmonised charging
is introduced when every vessel in the water will need to be licensed,
whether it is in use or not".
