wklein
does the Bav have a lead keel as the Swan does, IE weight where it helps, not just o/all weight
Bavaria will have iron as standard id imagine so thats 10% of weight accounted for
we have 52% ballast ratio![]()
You only have a 52% ballast ratio because iron is less dense than lead so you need more of it for the same righting moment.
Only have![]()
I also suspect the Bavaria is laid up with a CSM gun so strength is not equivalent to equivalent well laid up boat.
