Boat speed / speed through the water / sog
matt1
11 Feb 2005
Hamble, UK
My B&G manual doesn’t specify what boatspeed is even though it’s a distinct data field I can select to display. I get what sped through the water is and speed over the ground (Obviously) but does anybody know how B&G define “boat speed”?
MapisM
11 Mar 2002
Nope, actually STW stands for speed through water, and it's the one measured by the paddlewheel, hence unaffected by current.
What is imho a weird choice is calling SOG ...ermm, the SOG, and calling SPEED the STW.
Refueler
13 Sep 2008
Far away from hooray henrys
If the log is using Doppler - then it can be SOG based on either the seabed ........ or in deeper water - the thermal layer that exists ..
Just throwing a curve ball in there ................... doubt if OP's is Doppler though ...
RJJ
14 Aug 2009
I think it makes sense to call "speed" your STW. Perhaps just because it's what I grew up with and also as a trimmer/helmsman what you are glued to when racing.
Either way, it's not hard to verify if there's any tide around. Park the boat up against a transit or hold station under power near a buoy. Your "speed" will either be the speed of the tide, or zero. If the latter, it's SOG.
6 May 2020
I assume STW means speed to way point. Haven't looked at the type of function that I'm aware of so can't comment. I do use way points but SOG is adequate for me.
Surely STW is speed through water? There are only two options, water speed (log) or ground speed (GPS).
johnalison
14 Feb 2007
Essex
It was all much simpler in ye olden days, when you had to divide the distance travelled on the log by time, or was it the other way round? Most of us have come round to accepting:
1. boat speed from the paddle wheel, ie through the water, displayed on my Raymarine as 'SPEED'
2. speed over the ground, shown as ' SOG'
3. VMG to the wind or, aaaah
4. VMG to waypoint. Both the latter appear at different points in my system. You just have to know which is which.
  • Like
Reactions: DJE
RichardS
N/A
5 Nov 2009
Home UK Midlands / Boat Croatia
Although I'm one of the least of us who does not have a paddlewheel but still manages to display Raymarine "SPEED" and have a log which displays distance travelled. ;)
Richard
cpedw
1 Jun 2001
Oban
It's clear from my Raymarine system (dating from circa 2000) that it was developed using speed through the water because that was available. Then they discovered GPS and some things were adapted to use it so we now have the "True WInd" and the "Ground Wind". I can't remember which way round they are but one is based on COG and SOG, the other on Heading and Speed through the Water (I think).
Derek
Boathook
5 Oct 2001
Surrey & boat in Dorset.
My for speed through gives just the sp
Does also your Raymarine equipment say SPEED when it refers to STW instead?
Mine does, which seems to me a rather weird wording.
Says Boat kts and SOG kts. Also has VMG kts along with max and average.
matt1
11 Feb 2005
Hamble, UK
Thanks everyone. I think it must be speed to waypoint, on the basis that it was displaying 0.0 today (with no waypoint being navigated to) whilst “boat speed” was displaying x.xkn. So I think the problem was me assuming “STW” stood for speed through the the water.
Would have be helpful to have an appendix with all the abbreviations in the instruction manual :(
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
The instruction manual for my Zeus2 bears all the hallmarks of having been written by a computer geek who has never seen a boat. Full of the highly aggravating 'you can do this, that or the other' without saying how. The plotter is superb but there are still functions that I cannot use and things still happen that I cannot explain. The manual needs to be at least twice as thick as it is, with proper explanations. Not helped by the fact that I live on my boat for six months and then leave it for another six, by which time I have forgotten much of what I remembered last time. Thanks to Covid it will be 18 months this time.
