pvb
Basically, the electrical system in a start-stop capable car means the "starter battery" is no longer purely a starter battery and must provide power to the electrical system while the engine is off, it is therefore subject to a much more variable charging regime than was previously the case and has to fullfil the requirements of a starter and a leisure battery at the same time. Given the choice, car manufacturers would fit cheaper wet batteries as before, but wet batteries can't cope with the modern charge/discharge regime as well as AGM can. The AGM batteries fitted to cars are sized as small as they can get away with and are dependent on the vehicles electrical accessory content. More toys = bigger battery.
So you agree that AGM batteries are in fact OK for starting?
