Modulation
I'm moving my boat (a sea going sailing boat) for a while to a marina which is part of the Inland Waterways and one of the requirements is that the boat must be surveyed under the BSS code. So I downloaded the January 2013 Checking Procedures document to give myself a checklist to go through. It's not the easiest read and seems a bit prone to interpretation and is more than a tad repetitive. That said it's comprehensive.
Much of it is pretty commonsense stuff and effectively acts as a trigger to do things which are a bit overdue anyway - like gas hoses, gas regulators, fire extinguishers etc. But some of it seems to me to be unachievable without huge or unnecessary expense on my 23 year old boat. Two in particular stand out.
Reg 6.3.1 says each accommodation space must have at least two means of escape and each of these must accommodate a 380mm dia circle. My bow cabin has a hatch but it is a bit less then 380 by 380 so it can't comply. A bigger hatch can't be fitted as the deck becomes curved at this point. If the need arose, I can get out through it though. Even more difficult is my quarter cabin which has a single access and nowhere to put a second hatch without compromising the integrity of the boat structure. Very few (if any) boats from this era were fitted with hatches from the quarter cabin.
Part 7 deals with LPG systems and is very thorough. My gas bottle is stored in on open topped cylinder locker located within the rear locker. The cylinder locker has a drain hole at the bottom which drains directly into the rear locker and that in turn drains over the stern well above the waterline. Does this comply or do I need to install pipework to the cylinder locker - in my view totally unnecessary as no escaped gas can get inside?
I suppose my underlying question is whether the surveyors under the BSS scheme have the flexibility to use common sense. Or if they can issue waivers for unachievable requirements and then pass a boat?
Any info anybody?
Any info anybody?
