andyc
My boats been in for 2 seasons now.I was hoping to lift ,scrub ,re-annode and back in..Do you think it needs to come out for a period to dry out any interstitial moisture within the glassfibre?
Maxums best quality resin and what is gel-shield?
I have a binliner, so it comes out onto the chocks every winter because I'm afraid it will dissolve.![]()
Gelshield is an epoxy based resin which primarily replaces stripped back Gelcoat after osmosis treatment.
several coats are required followed by gelshield plus....
and OMG does it stink!!!
I was thinking light jet wash, polish the props,anodes and back in.
I am tempted to not anti foul.We have a tiny bit of slime that wipes off by hand and thats it after 2 years.
I was thinking light jet wash, polish the props,anodes and back in then perhaps take it out for a few weeks when there is space.Boatyard are not keen to take up space ashore this winter and it is more protected from sub zero temps in water.
Sounds like a good plan to me. Depending on the fouling level where you are, i'd be thinking about antifouling though. My current boat is a 2003 and has never been out of the water for more than a week.
Each year, we lift, pressure wash and chock up on the hard for a week. Replace anodes, polish hull, light rub down with scotch brite pad and antifoul, general check over and service then back in the water at the end of the week.
good tip for you...
if possible, jet wash the minute it is lifted to standing, or even on the hoist if there isnt any rush!
Any grass and frogs will come off far easier whilst still wet!
Simply scrub clean and treat with new antifoul if necessary.
There will always be a certain moisture reading with any boat pulled out.
It wont make a significant difference if it is popped straight back into the water after its TLC.
If there is a moisture problem, It will show up with osmosis blisters.
If there are a few blisters, dont panic.
They can be easily treated by your local GRP repairer.
Major pox is a different ball game. Expensive problem, but usually pops up on older craft!
The exception was Beneteau......
The history books nearly saw the company go broke with warranty work on newly built craft.
Osmosis being the culprit due to poor lay up!
Mines been in for the last 12 years. Dunno how you manage without antifouling though.
-----8<--------
Re. the OP - it's open to debate, but many surveyors recommend leaving out of the water for at least 4 weeks every years to minimise water absorption. That's what I tend to do, but it's your boat/decision...
A polyester hull is far less likely to develop Oomosis if it is dried out for six weeks or so every year.
Let your boat stand for minimum 6 weeks if poss to dry out and reduce the moisture content, this will significantly reduce the evidence of osmotic blistering, if your boat already has the pox, you will see the blisters shrink as the boat dries, sometimes they almost disappear. i like to take mine out every winter because if the marina does freeze over, it can damage blisters at waterline level.
This thread gets the prize for the most nonsense talked since someone asked about anchoring on scuttlebutt...
...Now this may be true! But even if they recommend it it still wont help. They don't know everything you know!!
...it's open to debate, but many surveyors recommend leaving out of the water for at least 4 weeks every year...
I know they don't know everything. That's why I said...
If it's duff info, why do most surveyors recommend lifting out and drying the hull? What do they have to gain (- or not lose-) by suggesting that?![]()
(P.S. - Not looking for an argument here - just wondered what a surveyor would gain by suggesting an annual lift-out if it wasn't good for the boat).
