Boat length/wave length
113.568 ft at 20°C, which is quite interesting as the same calculation gives a figure of 87.326 ft for the Solent which is counterintuitive!
So due to wave lengths there must be a figure to divide that by to give the ultimate yacht in the range 20-50' A friends boat is 24' and gets a pounding, ours is 32 but tends to slam off the waves and a 50' was similar so maybe 40ish?
I used the Holger Neilson formula,but now that C sail is introducing more variables I'm going to apply the Goldberg variation to refine the answer.
Would be interested to know what he's going to do with the result,perhaps a selection of boats to suit each wind strength,or perhaps Bow extensions to tune one boat.
There's no European standard (yet) for wavelength and period, but Brussels is working on it.
With typical British ingenuity, I suggest that until a binding standard is promulgated, we insert telescopic sections into our boats, so that we can extend the overall length (and the apron length, too) so that the boat and waves are always a harmonious, symbiotic partnership.
For the cat sailers, there will have to be lateral extendability as well.
As a side benefit, you will be able to reduce the length of th evessel so that you can afford marina charges anywhere.
As a side benefit, you will be able to reduce the length of the vessel so that you can afford marina charges anywhere.
Optimist! Any normal marina will charge on the maximum measurable length, not the minimum.
