Poignard
I have had my boat 19 years and never left a heater on. Plenty of ventilation is all that's needed.
If you have adequate ventilation, you don't need dehumidifiers. In around 40 years, I've never taken upholstery home in the winter.
As far as dehumidifiers are concerned, the main thing is to have one on a time switch, so that it DOESN'T run overnight, when freezing is more likely. MIne runs from about 0930-1630. Works well for me...
Have never had a problem over winter with decent ventilation, afloat or ashore.
I have always tried to ensure a howling draft through the boat, all year round, and this seems to work well.
If you are on board in the winter and warm things up, restricting the howling draft, you open things up again as you leave.
I have a cheapo compressor type in my garage. If it gets too cold, it switches off and the 'defrost' light comes on.
When it's that cold you don't really need a dehumidifier.
To get things dry, running it in the warmer part of the day seems most efficient.
The air 'holds more water' the warmer it is.It's the opposite - more water comes out of the air at lower temperatures so that's when you want the dehumidifier running to slightly warm the air and minimise the dew every night inside. In practice though after the first week of the boat being sealed up there shouldn't be much moisture left.
A great deal depends on whether or not you use the boat over the winter and what the weather was like when you closed it up if you are not going to use it. We spend several days on the boat every week, all the year round, and it would be a disaster without a dehumidifier. You spend two or three days aboard, cooking, eating, living with the heating on and the amount of water in the air builds up - but the humidity stays down because the air is being heated. You then turn off the heating and leave the boat - which cools rapidly - and the humidity rockets. We don't usually leave the dehumidifier running while we are away, but it is on most of the time we are aboard, so we leave a warm boat full of dry air - which translates to a cold boat full of relatively dry air. I'm just looking back on the logs from our boat - when we left it the temperature was around 20 degrees and the humidity was about 45%. At the moment, the temperature is 5 degrees and the humidity is 60%
+30 years. My wooden spoons go mouldy if I leave them, for some reason, but nothing else does.
