Simon RBG
New Member
Hello, I'm completely lost with this fault and could do with some help/advise. I have a fault with my BMW out drive leg trim system. I can make the leg rise to the rams full stroke but I can't reverse the action. Its like I have hydraulic lock. Motor attempts to lower the leg but stalls out.
I have replaced all the Hydraulic lines and blown through, stripped and re sealed the two cylinders in the system and electronically bench tested the pump and motor, works perfectly but as soon as I plum is up and test on my craft it just won't work. leg goes up, won't come down. I've even switched the hoses round and re wired the motor feeds.
I can't figure out what else I can do
Has anybody else come across this fault and can advise what I should be looking at doing?
Simon
Relcraft Boaters Group
Simon
