kalindi
With help from a previous posting I have solved the idling problem of my old BMC some months age and everything has been working fine, until now.
The engine starts well seems to have plenty of power and general has not been a problem. Yesterday all was ok on the way out of the harbour and after a reasonable sail I started the engine to make the return. The engine started ok but after about 10 mins I noticed a trace of white smoke from the exhaust, after another ten mins there was a slight increase in the running temp and then when slowing down to manouvre the revs seemed to increase and it sounded for as though it had come out of gear with no load. The prop was still turning and the boat still moving. I slowed down to about 3 knots and the temp returned to a little below normal and after a while it again sounded normal. After tying up and without stopping the engine I ran it out of gear at full throttle. The engine responded and a hughe quantity of black crud came out of the exhaust along with the water. After a while the black stuff disappeared and lots of clear water flowed through the exhaust. It now seems ok. Has anyone got any ideas about what was going on? I intend to check out the cooling system to see if everything is ok.
