Blue head flush sachet
Jabs
22 Jun 2011
Bursledon
I have just seen a 'tee' in the flush line to the head which is designed to take a sachet of something to make it smell better and to turn the flush blue.
What is it and who sells them??
Thanks.
Tony.
There are two variants, one must be fitted above the waterline, as you infer, the other (which takes tablets) can be fitted below the waterline. Here is the pdf showing how both types are fitted:
http://www.leesan.com/uploaded_files/datasheets/head treatment system.pdf
There is also a tee-piece c/w cock which allows fresh water to be flushed through before leaving the boat. This eliminates the Hydrogen Sulphide generation by flushing out the seawater which contains the bacteria which produce the gas.
http://www.leesan.com/index.asp?m=3&cat1=48&cat2=50&p=177&t=LeeSan Flush-It Kit
Rob.
