MapisM
Bart, since you asked for ANY advice...What does the forum think, any advice is welcome
I guess mine could appear as something which didn't take me a lot of effort, but I actually thought carefully about the possible alternatives.
And I tried to look at that from the perspective of both the owner of the boat, and also of a diver.
Bottom line, in your boots I'd leave it as it is, for the following reasons.
1) No matter how much money you're willing to spend, you'll never get a clean job anywhere near those of the other pics, because those boats are designed very differently, to start with (thickness and angle of the transom).
Frankly, I don't buy the idea that someone can make a great job just because he knows the boat very well and has worked in the yard which built the boat. In a sense, I would rather use that man just as a consultant to highlight all the potential problems of the modifications you have in mind, but without giving him any hope to get the job, if you see what I mean...
2) ...in fact, I'm willing to bet that there's some structural function in the thick GRP border above the steel rub rail. I mean, why didn't they cut the two transom doors further down, to make them level with the cockpit floor? That would have been much more convenient also on stbd side, for the passerelle access. And they could have cut also the rub rail, attaching it to the doors to make it look continuous when they are closed.
Instead, they kept a rather substantial border above the line where the deck is bonded with the hull, with a continuous steel rail all around that. There must be a reason, imho. Which is something only the boat designer (rather than the workers which actually built it) could confirm or deny.
Of course, I'm not saying that if you cut those parts the whole stern will fall apart, but I wouldn't take any chance to make it weaker, anyway. It's not that easy to strenghten all that again after you'll have cut it, you know!
3) To my eyes, the existing access to the platform is not bad at all, even for a diver with gear. As you surely know, it's much more difficult to return onboard from the water, climbing a ladder which typically is much worse that the one we're talking about: less large, less solid, and with shorter handrails - not to mention when some waves are bumping you around.
I mean, once a diver is returned from the surface to the swim platform, reaching the cockpit with the ladder you already have is a piece of cake in comparison. The only thing which your ladder doesn't allow is climbing it with your fins on (which is allowed by the ladders with a central pillar, often used on diving boats), but I don't think that should be a problem, because a) unless you have such type of ladder from the swim platform to the water, you must remove the fins already in the water, anyway; b) putting/removing fins on the swim platform should be reasonably easy even if it isn't so large, and c) also with the "newer style" molded stair, it would be very unpractical to reach the cockpit with the fins on.
4) Talking of resale value,TBH I think that you wouldn't recover one penny of such job. Actually, if the job wouldn't appear well integrated with the rest of the boat (as I fear it could be), or in the worst case, if it would negatively affect the structural strength, the boat could become extremely hard to sell.
All that said, I agree that if under the cockpit there's a utility room, it's a good idea to have a direct access from the swim platform.
But that shouldn't be too difficult, if seen as a separate issue from the stair/ladder: just open a hole in the middle of the transom (again, NOT cutting the hull/deck bonding) and stick a watertight door into it. Judging by the pics, it should be possible to use a flat door, possibly fitting a GRP groove on top of it, aligned with the existing one which runs across the whole hull.
I would also consider a larger swim platform. BTW, that IS indeed an upgrade which would make the boat more appealing and re-saleable, because that's something everyone expect these days, particularly on a boat as big as BA. I'd use the KIS principle also on that, though: just a fixed GRP extension, without the complications and weight of hi/low mechanisms. The cruising asset of BA is too nice to spoil it with some heavy mechanisms in the worst possible place for a planing boat...
