SimonA
My head gasket appears to be cream crackered, I'm getting lots of bubbles in the coolant and if I run the engine with the cap off the bowman heat exchanger the coolant overflows from the filler, I'm also losing coolant at a fair rate inside the engine. No other symptoms, engine starts without any problems. Oil looks thin and watery, but the level hasn't been going up so I don't think the coolant is going in the oil, and no mayo under the oil cap.
Has anyone changed a head gasket in a BMC Diesel engine? I'm not a hugely competent mechanic but can follow instructions, not sure if this is a DIY job or something I need to leave to a mechanic. Would the timing need to be set up after removing the head? (I've only ever taken the head of a petrol engine).
Does it require a crowfoot spanner for the head bolts under the rocker?
Finally has anyone tried something like Steel Seal or K Seal, or are these a complete no go for boat engines?
