Anthony
there are two ways a fuse blows the first is when the positive connects straight to earth and blows the fuse the second when the circuit is over loaded and you'll see the fuse wire melt
Technically there is only one way a fuse actually 'blows', and that is when it is overloaded beyond its rating causing it to fail. The positive is always connected to negative in any live DC circuit, its just a question of how much resistance is in the circuit as to how much current flows (ohms law). Its just that a short circuit is a very low resistance connection of positive to negative so a large amount of current flows.
Dependig upon the alternator, it is possible that the fuse fractured due to age (I have seen this on Volvos), however it may have had the knock on effect of damaging the alternator due to there no longer being a load on it, and now that damaged alternator is causing the new fuses to blow.
How long after startup dies it blow, have you tried putting a DVM on the alternator to see what the voltage gets to when running?
Anthony
Anthony
