cherod
N/A
I was not going to bother replying tonthis as it is neither helpful nor constructive , but hey ho ,,,,,, so , because it “ may “ be faulty i wont bother checking all other possabilities , get a grip man . Of course ( stating the obvious ) component parts maybe faulty but in my experience of buying new items very few do not work , it us the exception rather than the rule , maybe i am just very lucky or perhaps you are just very unlucky .Famous last words ... "it's brand new, it can't possibly be faulty".
If I had a quid for every time I've heard that from a client I'd be sailing a brand new Sirius 40DS instead of a 40 odd year old Westerly!
In reality, it's far more likely to be faulty when it's brand new than when it's several years old, just as likely, in fact, as when it's nearing the end of its useful life (it's called the "bathtub" effect because if you plot mean failures of a component or device over time, the curve looks just like a section through a bathtub)
This is fault finding 101 and the cause of much grief and angst to those who don't grasp the concept. Never assume a component or device is working just because. If you can't prove beyond doubt that, in this instance, the GPS *is* working, you have to work on the assumption that it *may* be faulty, Ditto the plotter
And if you've checked and double checked all the wiring and checked and double checked all the config settings and you're certain that it's correctly connected and setup, by far the most likely explanation for it not working is that something is faulty (either the GPS or the plotter and once again don't assume. The only way to know is to test one or the other using known working equipment to either feed a GPS signal to the plotter or read the output from the GPS. Any competent marine electronics tech should have the means to do that)
