ghostlymoron
Last year I found myself in the unfortunate position of having all my batteries discharged and unable to start the engine. I have 3 batteries - 1 engine battery and 2 leisure batteries. These are connected to the alternator via a diode box. The reason the leisure batteries were flat was due to a problem with the bilge pump but this does not explain the flat engine battery. One possibility is that the blocking diodes are not blocking and allowing current to flow between the two battery banks. Is it possible to test the diode box using a simple multimeter?
