Morpheous
My old sunseeker wiring diagram (kindly supplied by forumite) shows a blocking diode between battery charger and engine batteries. While investigating a problem with my new battery charger I discovered that I still read a small voltage - about 2 volts - on the engine batteries terminal of the battery charger.
Is this normal? Battery charger manufacturer said that the charger has internal diodes and does not need separate protection and my diode will cause a voltage drop. The implication being that it could just be removed. Is this correct or sensible?
Thanks in advance
Thanks in advance
