Blocked intake
billyfish
6 Oct 2020
Newtown creek, lots of sh--ty green weed pulled into the engine raw water pipe which has a 90° bend on entrance, is there a simple bit to go into the hole on the out side to make it into quarters so I th at it can't make a bung,,,if you see what I mean
billyfish
6 Oct 2020
Tried the pump. No good . eventually had to take it all apart and poke it out. 3/4 skin fitting straight onto a 90 then lever valve. Domed cage is what it needs
Sandy
31 Aug 2011
On the Celtic Fringe
duckduckgo.com
Whoever designed that 90° bend in the system needs keelhauled!
It should be as easy as removing the jubilee clips, pulling the hose off the thru hull, opening the valve and poking a screwdriver through.
rotrax
17 Dec 2010
South Oxon and Littlehampton.
We had an inlet blockage of very fine green weed some seasons ago off Langstone Harbour.
The old screwdriver was a non starter-it just moved a couple of strands at a time.
First mate suggested the spare insert for our posh corkscrew.
This worked a treat. The hose was removed, the blockage still stopped the water from blowing it clear.
Once cleared with the corkscrew insert I turned the seacock on and the resulting jet of water blew the rest out.
It would have been a far different matter with a 90 degree bend :(
rogerthebodger
3 Nov 2001
Change the 90 degree bend for a tee with a plug in the vertical leg of the tee.
You will be able to remove the plug to clear any weed
