Block sizes
Jools_of_Top_Cat
16 Dec 2002
When referring to blocks some chandlers like to say 8 to 10mm rope etc. others will say size 2, 3 or 4 for example.
Would someone please be kind enough to tell me the conversion from size to rope diametre.
Thank you in advance......
<hr width=100% size=1>Julian
<A target="_blank" HREF=http://www.topcatsail.co.uk>Top Cat Homepage</A>
ccscott49
7 Sep 2001
size 1 little rope, size 4 big rope!
Dragonfly wooden blocks, size 3, max 12mm, size 2 max 10mm size 1 max 8mm there are other sizes, but thats all the ones I use.
Jools_of_Top_Cat
16 Dec 2002
Thank you for that, it is easy when in a shop but buying on line makes it more scientific so to speak.
poter
4 Feb 2002
Still going south currently in Corsica for winter
www.fairhead.com
Julian,
what blocks are you looking at?
Just that the difference in standard blocks from Barton & ball bearing blocks is small enough to go for the ball bearing blocks all the time.
I even use the ball bearing blocks as guides.
barton do a good catalogue which is all blocks travellers track, etc. etc. not quite as technical as the Lewmar catalogue but comprehensive.
The Barton block sizes are:
Standard blocks
block 1 30mm sheave 8mm line
block 2 35mm sheave 10mm line
block 3 45mm sheave 10mm line
block 4 58mm sheave 12mm line
Cruiser blocks
block 5 54mm sheave 12mm line
block 6 63mm sheave 12mm line
block 7 70mm sheave 14mm line
They then go onto high load blocks up to 18mm rope.
I have got quite a lot of barton gear from various chandlers to refit Shady & have been impressed with their kit. The boomstrut is a great bit of engineering easy to fit & works.
The web site is:
www.bartonmarine.com
If you go there you also get block loads etc. also a tech help email.
have fun.
poter.
Jools_of_Top_Cat
16 Dec 2002
All I am after are a couple of 8mm or size 1 cheek blocks to build a lazy jack system while my mast is down next weekend.
I don't think I need a ball bearing raced block as 90% of the time it will be sat static.
I appreciate your help though
