schilde
The hull of my old Invader has quite a few small blisters. After reading all the stuff on osmosis in here and on http://www.yachtsurvey.com/ I am not too worried about the boat falling apart!
Most of the blisters are smaller than 20mm, mostly about 10mm so I am pretty sure they are just under the gelcoat, not in between layers. The thing is, I have scraped and burst several during antifoul removal (still ongoing!). What should I use to repair these minor cuts? Do I need to spend weeks drying out the hull (which is never going to happen)? Can I just repair with a blob of gelcoat? Do I need to use something stronger like 2-part epoxy (will it stick with some damp around?) or maybe should I use something like underwater repair which should set wet? I am a bit unhappy about adding extra chemicals to the chemistry that is going on already. The boat is about 25 yrs old and never had any blisters before, but moved from fresh water to salt about three years ago.
Many thanks for your tips or experience
Steve
Steve
