Does anyone out there know if any of the major outboard or outdrive manufacturers used the 12 spline (3/4" shaft I think) propellors that are used on the Enfield outdrive. Or can the larger 17 spline (1" shaft I think) props be persuaded to part from the centre hub for a 12 spline hub to be fitted in? I'm trying to find a 14" x 17 prop and they are very thin on the ground in this format. Any info or thoughts appreciated.
J.
J.
