G
Guest
Guest
For use in doors / walls / domestic situations - you can find "Blind bolts" in steel / alloy etc. Drill a hole, push through the tubular bit .... then screw is put through item to fix and then screwed into the tubular part. That expands to lock the whole thing to the door / wall etc.
Now my question is that often there are some really bad designed blind fixing items on boats that similar could really be valuable for .... I've never found "non-corrosive" marine quality in these fixings ....
Has anyone any idea if such exists ?
