Blimey, not long to the start of the season
tillergirl
5 Nov 2002
West Mersea
Just working back from a start of season date.
Assuming I put the boat on her mooring on Friday 4th May (which are the beginning of springs so I can get her off the beach), I need to neap TG on the 'beach' around Monday 9th April. That will give me a month to high pressure the bottom, stop up that seam on the inside of the bilge keel, rub down, undercoat and gloss the hull, do 4 or 5 coats of varnish, paint the deck, service the seacocks, paint the cove line, change the fuel filters and impeller (impellor?). Which means I need to take the cover off, raise the mast, replace the running rigging, set up the standing rigging during the first week of April. which means between then and now (10 weeks) I need to finish rebuilding the rudder (probably 8 days), varnish (10 coats) the prepared boom, the new floor boards, the new glass locker lid, the refurbished instrument pod and the very clever wooden end piece that fits in the end of the visible plastic trunking and the new iroko aerial mount for the GPS and Navtex aerials(assume two/three coats a week in this weather even in the workshop to allow it to harden sufficiently - which means probably 4 weeks), fit the new cable trunking, fit the new expansion tank on the hot water side, trace the air leak into the water system, refit the instrument pod and rerun all the wiring, replace the running of the DGPS aerial cable so its not visible/liable to be caught, fit the new Windex, wash all the ropes when SWMBO is out (note to provide M&S vouchers to be spent to keep her out of the way) and fit in 5 weeks miles away voucher earning in rather nice places and 4 days away voucher earning in an ok place.
I wanted to be ready earlier but I am not sure it is going to happen! Not sure I have time to be here!
Lovely out on the Blackwater today. Will come out for 10 days after the winter weather has arrived and then gone again. Rudder off for new seals, replace a seacock currently being left open, slap a bit stuff on the hull and back in. I love this high maintenance plastic :p
We pulled to engine out of it's nest over the weekend.
New flexible bearers on order.
Alternator being sorted to fit a sterling regulator that has been sitting in it's box for a few years.
Engine bay to be sound proofed if I can get the materiel at a sensible price.
Cutlass bearing to be changed
Stern gland to be overhauled (Some sort of oil bath seal)
I would like to fit a 3 blade folding / feathering prop in place of the 2 blade Gori to try to reduce vibration but they are very costly.
Apply a high quality antifouling.
Planing to stay in next winter and don't want to be scrubbing off to often.
There goes £1000.00!
Ready to slap on the antifouling (once I buy it). Otherwise nothing I cant do in the water - although still loads to do of course but isnt that one of the joys of boat ownership!!!
Any good deals on antifouling? Used SeaQueen a couple of seasons ago but think I got antifouling and growmore muddled up last year!
I've come to the conclusion having tried just about every type of antifouling available, that nothing is really effective, at least on a swinging mooring in the Roach.
In 2010 used the cheapest possible from the Dauntless Chandlery on Canvey Island [forgotten the brand, Cooper's maybe], and it was effective as anything. Went as low as 35deg and collected some gooseneck barnacles for my trouble, and back on the mooring for two months got a bit of long weed on the waterline. But overall it was as good as anything else I had tried. Didn't put my boat in the water in 2011 so haven't had to clean the bottom at all.
Jotun is good on the Orwell ,we have been in 10 months & only slime.its also much cheaper than leading brands too.
Dauntless have something new this year which I am going to try. In the past Tiger Xtra has worked well in Bradwell. Dauntless has (apparently one of only four shops that do) Hempel's Classic. I am told that this is for commercial use. It is eroding and compatible with Tiger requiring only a freshwater scrub first. It is in the same colours. He says I must use a proper mixer not a stick to stir it. At £65 for 2 x 2.5 litre cans it seems worth a go.
I am probably going to try Teamac this year after a chat at LIBS. As I am in a mud berth, I go onto a piece of hard standing called the 'beach' (ho-ho) and high pressure and paint between the tides. Seajet which I have previously used needs 17 hours to dry before launching, others as much as 43 hours (can't remember which) or performance is seriously reduced. Actually it was interesting how much the manufacturers reckon performance is reduced by less than optimum conditions during application (damp substrate, moisture in the air). A bit of self protection I guess in those statements but the drying properly before immersion is a biggy. Teamac do a version called 'Tropical Killa' (no I don't know why) which is used by a lot of fishermen between tides. So I'll give it a go. £83.30 ex vat.
Used Seajet Emperor last year, what a waste of money! (See avatar). This year fitting Jaycar ultrasonic antifoul (see threads various) and using Joton Seaqueen as well. Hopefully the Jaycar kit will help the Joton last longer.
Four coats of epoxy and three of Coppercoat - hoping that it's just a half hour lift to hose down and change anodes each year for the next ten! :-)
