dgadee
This has probably been done to death, but I am moving from a sensible self-bleeding Vetus to a 3gm and can't quite work out what I should be doing.
There is a filter just above the fuel tank. How do you bleed that when there's no way to force fuel into it?
There appears to be an electric fuel pump. When I switch on the engine key (and hear the high pitched tone) there is no vibration from this pump. Does that mean a possible flaw or just that it it doesn't take power from the on key, but when the starter button is pressed? The two are some distance apart and I'm on the boat myself.
I can understand the bleeding of engine mounted fuel filter and the high pressure side of the system, but fuel may not be getting that far.
This a new to me boat which has been out of the water for about a year without - I presume - having had the engine started.
