Jim@sea
In hindsight when I bought the boat last year I should have put a new engine in and I would have been sailing today instead of being threatened with divorce as every night when I go home I smell of diesel as my wife hates the smell.
When I bought the boat I took a chance on the engine, I went on a sea trial and for 5 minutes the engine sounded great, then it stopped and we had to be towed back.
After fitting a new lift pump, primary and secondary filters complete, new on/off valves, I go to the boat, bleed the engine, connect a hose pipe and it starts. Now runs on tickover for about an hour, then starts to (if it was a petrol engine I would say misfire) then it stops.
It still sound great when it is running.
Could it be the injector pump,
Unfortunately as the Thornycroft 154 (BMC 2.52 Diesel) is in a deep bilge area I cant get the Injector Pump out without taking the engine out which will cost a fortune as where the boat is there are no mechanics.
I have read that if you have an injector pump which may have muck in it or the springs sticking by putting Automatic Gearbox Oil in the pump for 24 hours can clean it.
Is this what I should do or what do you suggest,
Any advice gratefully received.
