eddystone
This is by way of anticipating issues as I had to abandon replacing fuel filters as I didn't have a 14mm OE spanner for engine fuel filter. On my previous engine, a VP 2002, I usually had a problem getting the CAV housing to refill with fuel from the tank after changing the filter element. Current setup is the fuel tank is roughly on a level with the engine although the CAV housing is obviously well above the fuel outlet at the bottom of the tank. Couple of questions:
1. Should the lift pump on its own have enough suction to fill the CAV bowl - if not what's the solution?
2. If the lift pump isn't doing anything, apparently one needs to turn the engine over maybe 90 degrees. How? I don't think the Beta has a socket for turning the crankshaft live the 2000 series Volvo Pentas. Churning with the starter seems a bit random as to what position the cylinders end up in; and if so should sea water inlet be open or closed?
