Prospect and Sunray
If your filter is anything like mine, I can't see how fuel emerges from the breather without first filling the filter, since the breather is at the uppermost point of the housing.
Seems very strange, and I would question how the filter has been re-assembled. Can't see how loosening the holding bolt would help.
Because filling any vessel with fluid will displace the air in it. If the filter is sealed then you will not get fuel in it as the air has nowhere to go. Cracking off the centre nut allows more air to escape so the filter should fill faster/easier. Sounds like the OP's filter assembly is correctly assembled as it is air tight.
