richardabeattie
I have a fairly new Racor (120 I think) and have tried to bleed it after inadvertently running the tank too low. Having half filled the tank I opened and indeed removed the bleed screw and some fuel seeped out - but I was expecting a proper flow of fuel. Is this because the level of fuel in the tank is still too low?
Once I have bled the Racor I then need to bleed the fuel filter on the Yanmar using the little lift pump handle but if the fuel line from the Racor to the filter is currently empty I assume I'm going to have to pump the lever for a long time.
