chriscallender
Bleedin\' Diesels
At the weekend I changed the fuel filters on my Bukh 20. I changed both the primary (CAV type) and the fine fuel filter on the engine. Its all running now so no big problem, but I had a bit of a struggle with the bleeding.
The problem is that the primary filter is well above the level of the fuel, so I can't get gravity to do the work when getting the air out the CAV filter and filling the bowl. The outlet pipe emerges from the top of the diesel tank, and then goes uphill to the primary fuel filter. In the end, I disconnected the hose from the tank, poured diesel into it via a filter funnel, and got the CAV filter filled that way. I suspect I could have made things slightly easier by making sure that the diesel tank was full to the brim. However, even then the fuel has to leave the tank by a connector on the top and then further uphill to the filter, so it can't be filled by gravity.
I'd like to make filter changing much easier to do in the future, so that if I ever get contaminated fuel I can change the filter without any struggle, even at sea if necessary. One idea I had was to fit some kind of pump between the tank and the primary fuel filter. How about those bulb type things that are used to prime petrol on outboards? I found this article
http://www.sailnet.com/collections/articles/index.cfm?articleid=woodto044
which suggests that they can be used on diesel engines. Failing that I could presumably find a 12v electric diesel pump but that seems like overkill and will be used so infrequently that it might not work when I need it.
So onto my real question. Has anyone ever fitted one of those outboard primer pumps to a diesel engine. Will it pump diesel OK? Will it help me bleed the bleeder? Are there any safety considerations that make this a bad idea?
Chris
Chris
