Fantasie 19
Guys - at some point a previous owner has had the idea of improving cockpit drainage by cutting two holes and putting a piece of plastic pipe in between them - sikaflexed at each end. The idea is good, but I'm not sure the execution is... there is nothing securing pipe to boat other than the sikaflex, I'm on a mud mooriing, and sure as eggs at some point the transom end will be under the water and I'll spring a leak... so I'm looking for idea's to fill a 2" hole (above the waterline) on the transom, and in the cockpit... idea's.....
I've discounted the idea of an actual skin fitting due to cost... ideally what I'm looking for is a 60mm dia plastic/metal plate with a threaded bolt on the reverse...
This is the cockpit end...
- glass it over - time/temperature constrained, but I'm kind of thinking that at some time I might make use of the hole on the transom (bilge pump outlet)..
- some kind of blanking plate? someone on another thread mentioned tap blanking pieces (for sinks), they're a little too small unfortunately...
- s/s washer with rubber grommet/sealant??
