sailorman
This winter we re-routed the forward sink drain and don't have time before launch to remove the old blakes through hull fitting. We can close off the valve and plug the hose that's on it but for a belt and braces before we come out of the water again next September, is there a way of plugging it from the outside?
Don't think that will work with the OP's Blakes seacock ?
Aiui, the preferred method is to file or grind out the hull inside and out with a 12:1 conical taper (ie width is 12 times the GF thickness) then lay up GF inside and out so the plug formed is self-bonded and cannot fall out even if it does not stick to the hull's older layup. Process is described in the West Systems book which is a free download on their website.
I would not use a wooden plug in the hole left by the seacock because I'd be scared of unseen rot eventually finding its way through.
Boo2
Yes Yes Yes
re read the OPs post he is launching this week, all antifouled up & wants a temp fix.
How`s the tiller
