Blakes seacock grease - a change in formulation ?
Malish
9 Nov 2004
Rochester, UK, boat in SYH
My trusty pot of Blakes seacock grease (dating from the 2000's) is almost finished so I purchased a new one, larger in size but seemingly a different product inside, going from a milky green to a clear green... When did that happen (and why)? Can't see it presenting an issue but wondered what the back story is.
I am surprised to learn that tubs of Blakes Seacock Grease ever run out.
I had assumed that, like most boaty potions and lotions, sales only continue because gremlins like to hide unfinished pots/tubs/tubes is lockers, bilges, sheds, boxes, etc., only to emerge when you have bought another and/or no longer need them again anyway.
I have a range of 'specialist' waterproof greases from various patent equipment manufacturers, but typically end up having to use the 'wrong' one, notionally for a different bit of kit, because the particular 'right' one hides until just after I've finished the task in hand. If it helps, I can confirm that outrageously expensive feathering propellor grease seems to work OK in Blakes seacocks. It's not bad for dinghy trolley wheels, either.
If someone needs to service a Blakes seacock, I'd offer the loan/use of my half-full tub of Blakes Grease, and also the almost full medium grit grinding paste Blakes recommend for lapping the cones (small pots of which grade for some reason are more expensive to buy than the commonly available twin pots providing both fine and coarse grades), neither of which I could use up in my lifetime, but I can't offer them because I only ever find them when I'm looking for something completely different. By the time I or someone else needs them, the gremlins will have moved them somewhere else again.
I'm just amazed that there are people who buy different proprietary greases for all the separate uses on their boats. I use a general common water resistant grease for all required purposes.
I have owned the same tin of Castrol water pump grease for years and use it for everything. It has a calcium based soap, highly water resistant and is grade C, so thick that a knife will barely cut it😃.
