PhillM
If you don’t fancy doing it afloat, is the anywhere you can dry out, like a scrubbing grid or harbour wall? This job could easily be done between tides.
I don't see that any of that makes the conical plug valve superior to that ball valve. ......
Being a cautious type I actually open and close it every time I leave the boat - I live aboard so effectively that is pretty much every day.
That's likely the cause of premature de-greasing. I'd do once a week.
If your hoses and double s/s clips aren't to be trusted when you're off the boat, then do you trust them when you're asleep?
Another tip for 'temporary bungs' is to use the cylinder of silicone that almost invariably results when the unused sealant goes solid. If necessary, it can easily be carved to fit and can be 'screwed' by hand into an opening without the use of a hammer; they seal very well because they adapt to uneven bores. I prefer them to the traditional wooden bungs.
