Sal7373
Hi there,
We have purchased a Birchwood 22. When it was filled with petrol to the top fuel fumes filled the cabin. We checked beneath where the tank is and there was a small amount of fuel. This has been cleaned up. There are no leaks anywhere in the engine or tank. We can only assume that somewhere between the overflow pipe and/or the breather there is a split or the breather pipe is disconnected as fumes still fill the cabin over time. The problem is accessing it to check. The only way it seems is to remove the throttle leaver and panel(but it doesnt seem to come off) or cut a hole in the inside wall. Any ideas? Or has anyone had this issue before? Thank you, Sal
